Valve Cover Gasket Problems
Old 01-01-2008, 04:56 PM
Audi_Skydiver's Avatar
Default Valve Cover Gasket Problems
So I have been trying to get my VC off for a bit now and I have 3! YES 3 striped bolts that I can't get out!!!! I have soaked them in PB blaster, grinded it down so I can use a flat-head screwdriver but nothing is working. Any ideas??? Here they are:
Josh
Old 01-01-2008, 04:59 PM
Karl's Avatar
Default RE: Valve Cover Gasket Problems
Grind the sides flat so that you can get some vice grips on them so it looks like this.. (_) if thatmakes sense.. but has a flat spot on the top as well
Old 01-01-2008, 05:00 PM
Ahh ok, I will try that.
Josh
Old 01-01-2008, 05:05 PM
Karl's Avatar
let us know, and make sure you grind off just enough to make it flat
Old 01-01-2008, 05:08 PM
viper9821's Avatar
Get Chuck Norris and they will just fall out. +1 for the vice grips idea, if you get a good surface for them to grip they can do wonders.
Old 01-01-2008, 05:11 PM
manufan's Avatar
If you have one of those hand impact drivers, the kind you hit with a hammer. Get a nice slot cut with your dremel and give it a shot with the impact.
Old 01-01-2008, 05:23 PM
manufan's Avatar
Like this one.
[IMG]local://upfiles/37095/3CE304748045404D8D168DD027588CD2.jpg[/IMG]
Old 01-01-2008, 05:34 PM
cincyTT's Avatar
I'm make believe
if you used the correct sized tools the first time this wouldnt of happened [8D]
Vise grips are wounderful
Old 01-01-2008, 07:20 PM
Ok, well I got them off... it was a pain. This is becoming more of a job then I thought it would be. I have the cover off now, but when I took it off a small piece of plastic (about 1/2inch by 12/inch) popped off my fuel injector harness and landed in my valve train. It ended up landing right on top of one of the holes that drains the oil back into the pan so I had to go fishing, VERY CAREFULLY for it. I got it out luckly. NOW i need to get it all put back together.
Oh and Cincy, I was using the right size tools. They were stripped when I first started to take it all apart so I am guessing the previous owner messed it up.
Josh
Old 01-01-2008, 07:25 PM
cincyTT's Avatar
I'm make believe
i figured you were, i was joking a little. I have however stripped a bolt or 2 using a screwdriver that was a little small.
Quick Reply: Valve Cover Gasket Problems
