valve cover gasket
valve cover gasket
has any one done a valve cover gasket on a 01 2.8 cause i think mine are leaking because when i pull out a spark plug wire it is soaked in oil and when i turn my car off or stop after driving for a while smoke comes from under the hood and i was wondering how hard they are to do
there isn't a writeup for the 2.8 (or i never found it) but its not hard at all.
really straight forward....
just follow the 1.8t write up (everythings pretty much the same)
https://www.audiforums.com/forum/diy-do-yourself-55/diy-valve-cover-gasket-tomritt-8418/
and make sure you do the cam seals as well. when i did my valve-cover gaskets i didnt do the seals and they still leak alil bit!
I just changed my valve cover gaskets this weekend on my a6. It took me about 5 hours of work. I was getting the smoke, that is why I changed the gasket. Just remember to mark where things go when you take things off. I would also suggest having the ramps to drive the car up on so it is easier to work on the engine. My back was a little sore from having to bend over so far. Hope it goes well for you.
