vag-com has detected codes but no CEL
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16251
Shop #: WSC 63351
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-10 - Please Register/Activate - Intermittent
16517 - Shareware Version. To Decode all DTCs
P0133 - 35-10 - Please Register/Activate - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8D0 927 156 DF
Component: AG5 01V 1.8l5VT USA 1010
Coding: 00002
Shop #: WSC 06435
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
can someone tell me what these 5 codes refer too? no check engine light or anything that i can see or feel.
Address 01: Engine
Coding: 16251
Shop #: WSC 63351
5 Faults Found:
Coding: 00002
Shop #: WSC 06435
Coding: 0273004284
Shop #: BB 24334
what does my codes mean? I am confused as to why you posted codes,in response to me posting codes.
He reorganized your post and defined your codes so that we see only what we need to see and is easier to read.
P0300-Random/Multiple Cylinder Misfire Detected
You had your coil pack(s) replaced? This could be old news. Your CEL would be flashing if this was a current problem.
P0303-Cyl.3 Misfire Detected
See above^
P0133-O2 Sensor Circ.,Bank1-Sensor1 Slow Response
Has your front 02 sensor been replaced? If not, replace it. They get lazy after 100k miles.
P1602-Power Supply (B+) Terminal 30 Low Voltage
You'll get this code if your run your battery dead, or sometimes when you disconnect it.
Clear them and see if any come back after a few days.
See above^
See above^
See above^
Thank you anyway 1.8T
