vag com codes help
vag com codes help
hello i got the following codes. I just finally got vcds lite working. anyone offer any suggestions? and anything cool i can do with the free one?
CDS-Lite Version: Release 1.2
Wednesday, 05 December 2012, 22:03:44.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: None
Controller: 8D0 907 557 N
Component: 1.8l R4/5VT MOTR AT D03
Coding: 06251
Shop #: WSC 01117
VCID: 3B09B4EF3A7D
1 Fault Found:
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8D0 927 156 T
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
VCID: 3E0FBDFB296F
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.LBL
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
VCID: 3701A8DF0655
__________________________________________________ ____________________________
Address 01: Engine
Protocol: KW1281
Coding: 06251
Shop #: WSC 01117
Protocol: KW1281
Coding: 00000
Shop #: WSC 00000
Coding: 06251
Shop #: WSC 01117
VCID: 3B09B4EF3A7D
1 Fault Found:
Coding: 00000
Shop #: WSC 00000
VCID: 3E0FBDFB296F
1 Fault Found:
Coding: 0265109043
Shop #: BB 34171
VCID: 3701A8DF0655
Address 01: Engine
Protocol: KW1281
Coding: 06251
Shop #: WSC 01117
Protocol: KW1281
Coding: 00000
Shop #: WSC 00000
Do a throttle body adaptation (search will reveal the procedure). Look up a thread about "Easter eggs" (aka hidden features) and you'll find a bunch of stuff. The best features I enabled on mine were auto lock/unlock, horn delete when arming alarm, one touch unlocking, and remote operation of windows and sunroof.
Clean the throttle body and do a throttle body adaptation. The fault code for the transmission is a phantom code since you scanned its ecu before depressing the brake peddel. It will disappear if you depress the brake peddel before you scan ecu 02!
ugh. more codes... installed chipped ecu last night, ran great, but eventually got a slight shudder in boost/wot. i was scarred trans was issue (autofail) but no trans codes. i got these:
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR AT D02
Coding: 06251
Shop #: WSC 06335
VCID: 3D0DBAF72469
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18089 - Shareware Version. To Decode all DTCs
P1681 - 35-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
P0300 - 35-00 - Please Register/Activate
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-00 - Please Register/Activate
Readiness: 0010 0001
seems like i have a misfire issue. plugs are like a month old. i put them in when i did timing belt and vc gasket. im going to go check the gap, and hopefully set down to .028" for the chip
Coding: 06251
Shop #: WSC 06335
VCID: 3D0DBAF72469
6 Faults Found:
