Vac line, coolant tank replacement
I have been getting CEL light, and mechanic mentioned vaccuum tubes. He already replaced one, which looked like some of your old ones, but the light came back and he's going to check for more..what are these and what do they do? I have been driving a bit despite the light on...thanks
You car stores vacuum created by the intake and uses it for other ****, like the brake booster. If one of those lines was junk, logic would suggest that they all are. replacement line can be had on the cheap at any auto parts store
I definitely wouldn't take it to a mechanic to have the vac lines replaced. You can get 10ft. of rubber hose from AutoZone for like $2 and do it yourself in an hour. If its causing a CEL, you definitely wanna replace them.
#18
3.5mm ID. Best price I've found is Flex Technologies - Your Silicone Hose Solution - get 15-20 ft and you'll have extra left over for another time.
james0013
08-23-2008 12:04 AM
speedmetal1
04-02-2008 06:48 AM
