V-Band?
Old 02-10-2008 | 08:17 PM
hmonay's Avatar
Default V-Band?
Hey
I was looking at the GT3071R turbo @
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
and I saw an option for V-band
the options for A/R
.63
.78 w/ Vband (split housing)
.82
1.06
My question is what does the split housing do?
What are its advantages and how does it compare
to the .63 A/R?
Thanks
Old 02-10-2008 | 08:23 PM
cincyTT's Avatar
I'm make believe
Default RE: V-Band?
Its called twin scroll. You take 2 runnersto one port and 2 ports to the other. The way the car pulses makes the spool a little bit faster. A true twin scroll with .78 housing should spool about the same as a .63 and still hold power longer and make more power. However, no one makes a twin scroll manifold for the 1.8t.
PS, you would also need to run 2 wastegates.
Old 02-11-2008 | 02:21 AM
chaos92287's Avatar
Default RE: V-Band?
mmmmmm...twin scroll
Old 02-11-2008 | 04:20 PM
cincyTT's Avatar
I'm make believe
Default RE: V-Band?
No, Tial V-band stainless housing. its 4-6lbs lighter and will spool faster and hold power longer
Old 02-11-2008 | 04:48 PM
sean1.8t's Avatar
Default RE: V-Band?
it's so damn beautiful!!!
Arnold needs to release his new manifolds
Old 02-11-2008 | 04:56 PM
chaos92287's Avatar
Default RE: V-Band?
ORIGINAL: sean1.8t
yes it is. looks so easy to intall too!
on a twin scroll side note tho, what ever happened to the twin scroll manifold jbs was making for transverse?
and wasn't someone making a twin scroll k04 for the 2.0t?
(im too lazy to research [8D])
Old 02-11-2008 | 11:01 PM
hmonay's Avatar
Default RE: V-Band?
Why does the ATP claim to have V-Band then?
http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
ATP makes available, a 500HP capable turbo hardware kit for the FWD 2.0T FSI, MKV VW Golf/GTI/Jetta and Audi A3 featuring a host of components such as exhaust manifold flanged for GT/T3 series, Garrett GT3071R dual ball bearing turbo with GT V-band exhaust housing outlet, Tial 44mm wastegate with V-band connections, 3" all stainless V-band downpipe and rear transition pipe to stock exhaust, wastegate reroute tube and v-band connections in/out, all stainless coolant and oil lines and fittings, 3" inlet pipe kit with 3" MAF housing along with intermediate inlet pipe with integrated breather ported connection, diverter valve reroute, intermediate charge pipe outlet kit to meet with ATP FMIC pipe.
Old 02-12-2008 | 12:43 AM
cincyTT's Avatar
I'm make believe
Default RE: V-Band?
Thats the GT Vband housing. Its a normal T3 flange and a v-band outlet. Its great for an easy install/removal of the dp. If you havent taken off a t25 5 bolt housing before, ill just tell you it sucks. The atp dps come with a flange to match your turbos housing (T3 4bolt, gt 4bolt, t25, ect) and then a v-band to connect that with the rest of the dp.
JavanT
03-07-2013 01:54 PM
Scigano
11-14-2010 04:49 PM
achTTung
08-03-2008 12:04 AM
RedShoeRider
12-11-2007 05:04 PM
apg96
03-17-2006 06:12 PM
