Upgrading Injectors and FPR before k04 flash
Old 12-10-2012, 11:12 AM
AudiTurbo's Avatar
Default Upgrading Injectors and FPR before k04 flash
So I have had my k04 in for about 2 week and I'm still running my k03 software (1bar). I am waiting for giac to email me back so I can send off my ecu for the pc-16 upgrade. I got my 315cc injectors and 3bar fpr today and I was wanting to know if it's ok to go ahead and install these with my K03 1bar, and k04?
Thanks
Old 12-10-2012, 11:39 AM
MetalMan's Avatar
Moderator
Not a good choice, just wait for PC-16. Do you have a FMIC?
Old 12-10-2012, 11:44 AM
AudiTurbo's Avatar
nope.
Upgraded intercooler hose, but looking for a upgraded sidemount
Old 12-10-2012, 01:06 PM
jonbonesjones's Avatar
Moderator
You need a fmic for the k04? Doesn't sound right
Old 12-10-2012, 01:17 PM
CCA4's Avatar
Don't NEED it, but it would certainly help lower IAT's. I think an upgraded SMIC like Apikol or Boost Factory would suffice. I agree though, running K04 fueling on a K03 tune is a bad idea. Just install it all at once.
Old 12-10-2012, 01:43 PM
AudiTurbo's Avatar
I will be waiting for the tune
Thanks
Old 12-11-2012, 10:23 AM
Moderator
its still such a small turbo, wouldn't a side mount prevent some major lag?
Old 12-11-2012, 10:59 AM
MetalMan's Avatar
Moderator
Perhaps, but it might only reduce spool by 1-200 RPM at the most I'd imagine. From my experience, the piping for a front mount has smoother bends and less angles than the SMIC setup, which is definitely worth mentioning (greater pressure loss due to larger angles).
Old 12-11-2012, 11:35 AM
Moderator
damn, thats all you loose in spool. Then a fmic is def worth it, should significantly decrease air temps
Old 12-11-2012, 06:06 PM
CCA4's Avatar
Long as you get an appropriately sized front mount i think it would be fine. Plenty of guys run smallish front mounts with K03/K04 sized turbos.
Quick Reply: Upgrading Injectors and FPR before k04 flash
