The Unofficial B5 A4 Chatterbox
Old 07-07-2012, 11:15 AM
CCA4's Avatar
It's 11am and the heat index is already 105*. I wish I had a garage. Takes all the fun out of working on cars
  #782
Old 07-07-2012, 06:48 PM
jonbonesjones's Avatar
Moderator
go to the junkyard they literally ran out of water...... wtf
  #783
Old 07-08-2012, 04:26 AM
kriptonik's Avatar
How did it go, Chris?
  #784
Old 07-08-2012, 08:31 AM
Moderator
are we speaking of an exhaust install? or a clutch install?
since this is a chatterbox I'm assuming it means ask random questions you want a quick answer to?
is the a6 2.7tt engine harness the same as the s4 2.7tt?
  #785
Old 07-08-2012, 12:09 PM
savantv's Avatar
re: garage, AMEN!
  #786
Old 07-08-2012, 04:32 PM
CCA4's Avatar
Meh. Narrowed it down to the inner CV joint on the passenger's side. They both went within 100 miles of each other.
Bones, trying to track down a clunk on my gf's TT. Chatterbox means you can talk about whatever you want, basically an off-topic forum inside the B5 forum. I don't know much about the 2.7TT, but I can't see it being a ton different between the S4 and A6.
Originally Posted by savantv
re: garage, AMEN!
I know right?
  #787
Old 07-08-2012, 06:28 PM
kriptonik's Avatar
Damn, that sucks Chris. Get some Raxles and make sure those things don't break again anytime soon.
To answer your question, the S4 and C5 engines are mechanically the same (as they both are APB engines) though the C5 was built for comfort in which the engine produces less power and torque compared to the S. I believe this is resulted from different ECU's.
  #788
Old 07-08-2012, 06:38 PM
Moderator
sounds like the harness is the same
i just wanted to start a quick ? thread where you ask a question that you don't feel like starting a thread for because it won't tasks more than one rply to answer but it seems as i have found it!
  #789
Old 07-08-2012, 07:34 PM
vgo's Avatar
vgo
vgo is offline
Waiting for control arm kit to be delivered from ecstuning. I grabbed their cheaper kit, but still heavy duty upgrade. I'm pretty scared getting stuck with the pinch bolt.
  #790
Old 07-08-2012, 08:46 PM
Moderator
don't be scared, use an air hammer
Quick Reply: The Unofficial B5 A4 Chatterbox
