turn signals wont work-ep35
I just bought a 1999 audi a4 avant 1.8tqm and the turn signals and hazards do not work. i went to the local auto parts store and they said it is the ep35 fuse/plug. However i cannot find it anywhere inside the car
does anybody know where it is? a picture would be awesome
thanks
thanks
Yep, I'd bet that it is the relay, too. Happened on my B5 a long time ago.
okay thanks that helped a lot. i didnt think to seach for hazard relay or anything like that i just searched for the turn signals.
ive got two more questions tho. when i depress the clutch it takes a second before the rpms drop so i have to keep the clutch depressed longer for smooth shifts. any ideas?
also, when going above about 25 mph and turning left or once i go above 40 mph its a constant noise. it sounds kind of like an engine when revved higher into the rpms but different gears/rpms do not change the noise, only speed. my guess is a wheel beaing, would i be right in that or am i completely off?
thank you for the help once again
and i did search but couldnt find anything that seemed very definitive
