Turn signals not working
Old 10-24-2010, 07:00 PM
Ramathorn's Avatar
Default Turn signals not working
Hey i have a 99 Audi a4 2.8lqm no face lift and my turn signals have completely died. For a while they would turn off go intermittent and then turn off. Now they never turn on also my hazards do not work as well. Researching this problem it looks to be the relay in the hazard light switch. My question is in my research this problem only appeared on face lift or newer vehicles does the relay problem still apply to the non face lift. If it is the relay is there a way to fix it and then is there anywhere i can find it for less than $60.
Old 10-24-2010, 07:29 PM
Ramathorn's Avatar
would i be able to use a hazard light switch out of a 99 passat with a 2.8l and then switch out the cover on the relay with my current cover on mine to get it to match the interior. Would this be possible and has anyone done this?
vw part #P3030-133172
audi part #W0133-1622539
Old 10-24-2010, 07:36 PM
Andrew149's Avatar
this happends to all pre faceleft a4's i think purems has the best price on the hazard switch i replaced mine it took me like 5mins really easy to do and the turn signals work again
Old 11-17-2010, 11:38 PM
SPhilli911's Avatar
So I have the same issue with my signals not working (I haven't tried the hazards), but my A4 is a 2000. Same fix?
Old 11-17-2010, 11:59 PM
ImTheDevil's Avatar
Yes same fix.
Old 06-10-2012, 06:12 PM
Mtorout's Avatar
I have an 01 2.8 a4 the signals worked and wouldn't work for about a day and then died my hazards still work though that's the difference between mine and the other guys posting. What's a facelift?
Old 06-10-2012, 06:40 PM
morpheous's Avatar
preface lift is any A4 B5 1996-1998,facelift is any A4 B5 1999-2001
The facelift,regards to the headlights,preface lift has 2 piece headlights,facelift has 1 piece headlights.
Old 06-10-2012, 07:25 PM
kriptonik's Avatar
Actually facelift is from 99.5 and up. There are some 1999's that still have the per-facelift features.
Old 06-10-2012, 07:32 PM
makaveli7's Avatar
i had an issue with signals on my red audi and i literally pulled out the hazard light button and tapped it and they worked fine from then on lol
Old 06-11-2012, 12:03 AM
morpheous's Avatar
My turn signals,started to work,intermittently and then stopped working,all together about a month ago.
I attempted the hazard switch fix and it worked for only a day and the issue returned,so i bought a new one for about 53.00 shipped,installed it and turn signals work,good as new.
Quick Reply: Turn signals not working
