turn signal sticking
The turn signal relay is in your hazard flasher which is the triangle right above your radio. It is a VERY easy fix and a common thing to go out. You can get a new one here - http://www.autoanything.com/relays-s.../201A2294.aspx
Buy the radio removal keys at Walmart for $4, slide the radio out without unplugging it, reach in and push up on the back bottom of the hazard switch. That'll tip it forward out of the dash. Grab it, pull it out, unplug it and plug in the new one, then reseat it and the radio and you're done.
