turbo touble!
Old 07-26-2010 | 07:06 PM
halfpint's Avatar
Default turbo touble!
Hey guys i have a 1997 A4 1.8t with 83k miles i got the giac chip from awe tuning didnt have problems with the turbo until i put a carbonio cold air intake. it use to work on and off and found out the D/V was sticking so got a new one, and worked for a bit. Now it works but does not have as much pool any ideas?
Old 07-26-2010 | 07:12 PM
onepoint8tee's Avatar
Pull? Did you install the MAF in the right direction? Double check all the connections electrical (maf, n75, etc.) and hoses that were disconnected for the install.
Old 07-26-2010 | 07:16 PM
halfpint's Avatar
yeah everything is hooked up right and i dropped a new n75 in and nothing still
Old 07-26-2010 | 07:42 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Do you have a boost gauge? What is it reading?
Old 07-27-2010 | 03:49 PM
halfpint's Avatar
no i dont have a boost gauge, but u can tell when it worked it spun the tires at like 3 1/2k rpm now its a turd
Old 07-27-2010 | 10:12 PM
The Bishop's Avatar
I would replace the entire vac line from the DV to the mani
Old 07-28-2010 | 03:25 PM
halfpint's Avatar
yeah ill try that but i mean u can hear th DV workin and the turbo spoils a lil but the backs off even when i have the pedal to the floor
jessiec132
09-05-2007 04:20 AM
CamoA6
11-08-2006 02:09 AM
mr V8
18
06-23-2006 03:21 AM
Quick Reply: turbo touble!
