Turbo replacement question
Old 01-23-2014, 07:23 PM
Pbcrazy's Avatar
Is there some way to fix that? Maybe spraying compressed air into the tube connected to the n75? I really don't want to replace the turbo again...
  #22
Old 01-23-2014, 07:36 PM
Pbcrazy's Avatar
Or maybe some way to diagnose it?
  #23
Old 01-23-2014, 07:51 PM
redline380's Avatar
Legal Moderator
first I would spray air into the wastegate line itself, not through the n75 and watch it open. are you 100%, and I mean 100%, positive the n75 is hooked up right?
  #24
Old 01-23-2014, 08:01 PM
Pbcrazy's Avatar
If you are looking at the n75 from the passenger side, sensor plug facing you: Left is to the compressor housing, down is to tip, and up is to the wastegate. The turbo did come with a skinny line attached to the wastegate nipple (smaller than I would normally use) so I didn't bother replacing it, does the wastegate need a lot of air or just some?
  #25
Old 01-23-2014, 10:06 PM
redline380's Avatar
Legal Moderator
Don't tell me directional, tell me by nipple length (notice how each nipple is a different length). Also ensure that all lines have zero leaks
  #26
Old 01-23-2014, 10:28 PM
Pbcrazy's Avatar
That is 100% how it is set up. Could the diameter of the line be a problem? I highly doubt it because of the minimal difference
  #27
Old 01-23-2014, 10:50 PM
redline380's Avatar
Legal Moderator
I highly doubt the line is the issue. You need to make sure there is nothing wrong with the lines at all.
Also, grab the wastegate rod with a pliers and see how hard it is to open the flapper
  #28
Old 01-23-2014, 11:11 PM
Pbcrazy's Avatar
The lines are correct, I can take a picture if that helps. When you say move the wastegate rod, how hard should it be to open?
  #29
Old 01-23-2014, 11:28 PM
redline380's Avatar
Legal Moderator
it should give a fair amount of resistance, enough to have to try to move the rod. maybe 15lbs?
  #30
Old 01-24-2014, 11:23 AM
Pbcrazy's Avatar
It didn't move a bit even with a lot more force than required to move my old one, is there anyway to unfreeze it?
Quick Reply: Turbo replacement question
