Turbo questions/advice
Im the proud owner of an 01 1.8t A4. Ever since I bought it a year ago, it makes a loud whine when it starts, which goes on for a few minutes. I never thought anything of it until recently (couple weeks ago) when i bought it in for an oil change and one of the pit crew mentioned it might be a problem. Last week it started to make a noise when i accelerated, almost like theirs air sucking in from somewhere. Only happens when i accelerate past 2500 rpms, and doesnt make the sound when im not moving. looking for any advice; im not sure where to go from here.
Hope you don't mind, I moved your thread to the B5 A4 section where it is likely to see more traffic and general helpful replies.
If there is a loud whine after a cold start for a minute or so, that might be your Secondary Air Injection (SAI) pump going bad.
Sucking sound could be a number of things, like a torn rubber hose causing an air leak. You could perform a "boost leak test" to check for torn hoses.
