Turbo info k16
Old 01-04-2011, 11:44 PM
zerokiller698's Avatar
Default Turbo info k16
So I came across this beast for cheep, recently rebuilt.
Its the K16, the bigger of the K16 series as i can tell. That is all i know about this particular unit. Does anybody know what the capabilities of this turbo are and what i need if i want to put this on my 1.8t
http://i3.photobucket.com/albums/y92...g?t=1294202604
Old 01-05-2011, 01:18 AM
FASTER's Avatar
Tech Slut
A different manifold, different cat/dp, tuning, charge piping, and whatever else lol.
Old 01-05-2011, 08:06 AM
CCA4's Avatar
Is that all? I'll take two
Old 01-05-2011, 11:12 AM
Msnickbroderick's Avatar
Actual WIZARD
I didnt know there was a k16.. Its kinda funny with the huge wheel, but rather small housing. Anyone have a compressor map? Id assume you would need a custom mani (or just a top mount with a different flange), then basically think of it as an elim kit (IC, tune, piping, injectors/rail/fpr combo, clutch, etc)
Old 01-05-2011, 11:33 AM
Mike-2ptzero's Avatar
A manifold to fit that turbo onto a A4 1.8t is not easy to find. It is going to spool slower then a GT28rs and make power like a GT28r.
Old 01-05-2011, 12:45 PM
I figured a manifold would be hard to find. You think getting the computer programed to the gt28r would work? I've heard this turbo compared to the gt2871r
Old 01-05-2011, 01:40 PM
FASTER's Avatar
Tech Slut
Yes, but not ideal. It would have to be a bit tuned down. Youre probably better of either getting a dyno tune, or scrapping the idea altogether and finding a turbo that is more common on our cars.
Old 01-05-2011, 10:08 PM
hauptjr's Avatar
OK - so what turbos are more common to our cars? I'm adding oil every 2 weeks or so. Its seems to be leaking from the turbo (at least it is leaking down a line that goes to the turbo), and I seem to be blowing a lot of smoke.
So, what is the least expensive way to replace/swap out a turbo? Its' my daily driver, so I cant send the turbo off for rebuild and wait for it to come back.
Old 01-05-2011, 11:28 PM
FASTER's Avatar
Tech Slut
Cheapest and easiest way would be to buy a stock replacement k03. But if your going for more power there are almost unlimited options ranging from about 2 grand and up. If you can find a used eliminator, or full turbo kit thats in good shape, then you'll save alot. Someone posted a used APR stage 3 kit for about 1900 iirc. Not sure what head port the mani was setup for, or the tuning, but I believe it was for an 06a, small port setup.
Old 01-05-2011, 11:45 PM
turbo kraut's Avatar
Tech Guru
it was for a 2000 a4, but it is sold
and there you go again pimpin' elims
Quick Reply: Turbo info k16
