Tune question
Tune question
I got maestro for my Jetta...i know wrong section, but the B5 guys are my fav and are smart and can solve this.
I just got stage 1 tune
colder plugs gapped to .28
I have a slight miss in third and when i get on it. All coils I'm guessing are good because they worked prefect before the tune. Its not pulling a misfire code but I can feel it. Where do i Start?
if you got maestro run some logs. it should tell you exactly where your misfiring and how bad and if timing is being pulled. also, word of advice, if you got a spare $80 sitting around you might as well upgrade to fsi coils if you havent already since you will be in the future.
I already have the FSI coils. They are fairly new AFAIK so im staying away from that theory.
I took some logs yesterday but didn't really pay attention and forgot to save. What am I looking for in the logs? Will it be obvious? Or do I read every number and find the ones that don't fit?
Thanks for the help Redline.
ive done a decent mount of research on plugs and ive come to the conclusion that expensive multielectrode plugs are only better than standard copper core plugs in one way: longevity. by all means id try some different ones. you never know what youll find. btw what plugs are you running? bkr7e's i assume?
