Trying to get my VCDS-Lite to work.
Okay I can't get this program to work. I purchased this OBDII cable from ECS.
http://www.ecstuning.com/Search/VT1A0003/ES6928/
I downloaded driver software from this site and version 2.08.08.
http://www.ftdichip.com/Drivers/VCP.htm
I then downloaded VCDS-Lite release 1.1 which is at the bottom of this webpage.
http://www.ross-tech.com/vcds-lite/download/index.html
I extraced the files from the folder for the driver and installed and my computer recognized that it was a serial to USB converter.
When I run a auto scan it keeps running and opening new ports. So I closed the scanning and did the OBDII check and it gives me this error.
Car is NOT ISO/OBD-II Compatible! IF this car is a VW/Audi/Seat/Skoda Try SELECT > Individual Controllers.
I can't find this Individual Controllers option.
Anyone familar getting this program running because I am lost.
what do you mean test properly? I was able to find the correct COM port and it acted like it was able to read the cable in that COM port. When I go to test it keeps searching for something and will got to a different number of a port or terminal or something.
