true HID vs conversion kit
Old 11-21-2008, 04:06 PM
jlaudio184's Avatar
Originally Posted by Gigantor
But doesn't my 2000 A4 1.8tqm already have HIDs? They certainly don't look like your average headlight. Except the brights...
all depends what came factory on your car, some did, some didnt
Old 11-22-2008, 08:15 AM
relliMmoT's Avatar
you might be talking about projectors. your car has projectors for headlight lenses instead of the conventional big housing lenses.
if your car has HIDs from the factory the way that you would tell... hm
are they bluer than conventional headlights? i think the stock audi HIDs were 6000k, pretty blue.
when you kick them on, do they kick on INSTANTLY like an LED, and then take about 10 seconds to fully brighten?
other ?:
NO, Audi A4's use single beam, dont get the bi-xenon dual beam. thats for housings that you notice only one headlamp bulb to put it easiest.
Old 11-22-2008, 09:53 AM
ImTheDevil's Avatar
If you have HIDs, when you turn them off, they literally vanish. And as they said, bi-xenons are meant for cars that have one bulb for low and high beams. The Audi uses separate bulbs for each of those, so to have xenon for both, you need two single-beam kits.
Old 11-22-2008, 03:24 PM
Quattro_1.8t's Avatar
stock audi HIDs are 4300K
Old 11-22-2008, 04:42 PM
MrFlippant's Avatar
Originally Posted by hcaudikeed
Originally Posted by MrFlippant
Yes; the factory HID's are installed at the factory, a conversion is installed in your garage.
i think he was referring to the quality and brightness of the light as compared to a factory setup. if it would look the same.
LOL Damn, forgot I even posted in this thread! Sorry, I'm kind of an *** when I'm drunk.
Old 11-22-2008, 07:02 PM
strudel's Avatar
Try this advertiser from on site to compare. JS http://www.xenonhidworlds.com/
Old 11-23-2008, 02:24 PM
Lazer Viking's Avatar
the difference between factory installed xenon, and a hid kit will the be projectors.. xenon projectors are different with their beam cut offs and reflectors
96-99 will not have projectors and you can not put a hid kit in them
99.5+ will have projector housings, and may come factory equipped with xenon
normal halogen projector housings will have h7 bulbs where as xenon housings will have d2s bulbs
if you have a 99.5+ car without xenons factory, you will need an h7 hid kit
  #18
Old 11-23-2008, 09:35 PM
ImTheDevil's Avatar
Well, technically you can put the H7 kit in (I did that before I got my Depo lights) but the beam pattern isn't optimal and it throws the light around rather than focusing it as it should. That being said, the OEM reflector lights suck so badly with halogens that anything at all is an improvement, and the HID upgrade in those lights definitely helps. It doesn't hold a candle to the HID output in projectors though. With the Depo lights, halogens put out better light than HIDs in reflector housings.
  #19
Old 11-24-2008, 08:36 AM
so how come some projector lights say that they are halogen only and you cannot use a HID xenon coversion kit?
  #20
Old 11-24-2008, 12:24 PM
PunchyTable's Avatar
I have HID's and Projectors on my A4. I got basically the same Projectors you have there. and I have 6000k HID the cost for the HID lights was around 200-250.
Quick Reply: true HID vs conversion kit
