Trouble Removing Wheel/Rim/Lug Bolts
Hey AF!!
Long time... I haven't posted on this site in ages but I have been checking in and keeping up from time to time. As usual, I'm back here looking for your wisdom... My car has been in storage for years now and I slowly want to start working on it again (-won't be driving it for about another year). A couple months back I spent hours trying to get the wheels off with no success. I tried wiggling them, knocking them lightly with a rubber mallet, using a breaker bar for leverage and endlessly torching the lug bolts (thinking loctite might have been applied to the bolts). I eventually gave up.
I want to tackle this again because I want to pump and rotate the tires and have one tire patched. What are my options if the lug bolts have had loctite applied? And what else could be securing the wheels so strongly (-after about 2-3 hrs I think I got just one bolt off)?
Also, I somewhat recklessly had the car just sitting (in a garage) on 3 tires all this time, which I'm sure might have permanently warped the 3 grounded tires. Will these tires be okay? Is it necessary to set the car on stands?
Thx in advance for any insights!!
Looking at your location you probably have nature welded lug nuts aka rust. You might have to apply heat to the lug bolts. As far as removing the wheels a large pry bar from lower control arm to the rim is good for leverage. Never beat a rim off.
Hey AF!!
The car was always fully enclosed in a garage so it was never exposed to moisture, so I didn't think rust would be a factor for parts not exposed to engine fluids.
Thx for the quick replies!!
@Huskerbob - I definitely won't be applying loctite to them in the future. lol. I'm almost certain loctite must be on there now because those wheels are on really good.
If new tires are needed, then I won't patch that tire but I'll keep these ones on until the car is ready to be driven. I suppose it's better to leave the car on stands?
p.s. ...such a shame, those were brand new Kumho tires are on there; but I was going to switch them out for winter tires anyways.
Thx, I'll definitely try that out after first giving it a go with the some heat again. ...way wayy after. lol
I was thinking it would melt/break up any loctite that might have been used on the bolt threads.
Heat will loosen rust & melt locktite. I am assuming the car is driven in weather conditions which includes salting the roads. This salt is what causes rust , does not matter if the car is garaged or not. YOU HAVE A RUST ISSUE! You will need heat! Not just a propane torch , you will need oxygen & acetylene to heat to sufficient temp.
