Trouble Codes
Trouble Codes
Well got my obdII detector hooked up and got these codes, question is I know what they are but how do I go about fixing them.
Engine
16684/p0300-Random Misfire detected-any cylinder
16685/p0301-cylinder #1 misfire
16689/p0305- Cylinder #5 misfire
16690/p0306-Cylinder #6 misfire
17804/p1396-Engine speed sensor-missing tooth
17736/p1328-cylinder #4 knock control limit attained
SRS
01025-Malfunction Indicator Lamp Faulty
00532/p1746- Transmission Control Module Relay-Supply voltage (B+) malfunction Low Battery or Bad Ground
thanks in advance guys.
Engine
SRS
I was gonna replace all the wires and spark anyways, when I do that ill try. My main thing is that speed sensor missing a tooth.
I have the v6 and when I called they said no recall on those igntions. Only recall i have on mine thats still open is the ignition switch which im getting repaired tomorrow.
