Trick to tightening front lower control arm onto knuckle?
the allen should just be for holding the ball joint from spinning, you torque the nut which will act normally as it would without holding the allen, you would have to use an open end obviously if your using an allen socket on the end but you shouldn't be torquing the allen. jus the nut.
MattP87
03-22-2010 09:25 AM
