Transmission issues
Transmission issues
I have a 1998 A4 2.8 quattro 5sp and it makes a grinding noise while in first gear but it goes away in the rest of the gears..
any ideas of what it might be??
thanks for the help!
and i were to want to replace the tranny what kind of tranny could i replace it with??
does it have to have the same tranny code and same everything as my car??
i love the car i dont want to have to part with it!!!
thanks again
thanks again
I would start saving. Try to get by and get a used manual transmission. They can be found. Only way to know what is going on right now is to drop the transmission and open it up. Don't bother, just if it gets worse you will know what is coming. You can change your fluid out if you haven't already, but some will suggest leaving it in due to it "holding things together".
