transmission issue i think
hey everyone im new to this audi and forums thing but just needed a smarthead with this one, ok when i shift into 1st gear it makes a rattle noise but all other gears are fine ,one mechanic tells me its the sincros(hope i spelled it right) please someone help me if you can
A bit difficult to say for sure based on that description, but its possible. "Syncro" is short for synchronizers, they're sorta like lil gates that keep you from shifting like a dipshit, say from 5th to 1st or something, while the car is moving. They do wear out. In addition to the noise you're hearing, is it harder to get the shifter into 1st than the other gears?
1st and 2nd gear synchros wear out often. especially from people trying to downshift from 2 to 1 while the car is still in motion. without anymore information thats all that i can tell you. you can try flushing the trans fluid.
it would be cheaper and easier to replace the whole thing. new synchros will cost about as much as a good used trans will ($400-8000) let alone installation costs. i certainly wouldnt be thinking about replacing a transmission if the only symptom is a rattle.
I have the same thing going on with my 1999 A4 2.8 whats the possibility of damaging the gearbox further if i just keep driving with my synchros fucked? lemme know because I don't got a whole lotta money at the moment and would like an easy fix if possible.
This is not a syncro issue, it is apparently a chip in a tooth in the actual first gear that causes this problem. As you can see by the number of complaints about this, it is a fairly common problem with these cars although Audi doesn't recognize it as such. I've been told that first gear is an assembly that includes reverse but that the labor required to do this job is basically cost prohibative. I'm searching for more info myself on this issue. You really cannot even trade the car in with this noise because when they hear that noise they'll immediately tell you your car isn't worth anything.
