Transmission Fluid Change
Old 12-16-2012 | 05:06 PM
DillonT's Avatar
i will take pictures this week when i do it. You can just use a little siphon pump, or a small hose and funnel.
and assuming the ones i have fit, you can get them at autozone diff was just regular hex bolts fyi too
Old 12-16-2012 | 05:37 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Originally Posted by CCA4
I need to drain/flush/fill my gear oil as well..
Peace of mind + smoother shifts. Get on it. Don't forget the rear diff.
Old 12-16-2012 | 06:11 PM
CCA4's Avatar
Does the rear diff take the same gear oil as the trans? I really should have done both of them this summer but between my car and my GF's TT I ran out of good weather.
Old 12-16-2012 | 06:38 PM
jonbonesjones's Avatar
Moderator
it can take gl5 or gl4 vs the trans that takes gl4 only, brass synchro friendly
Old 12-16-2012 | 06:49 PM
I used Redline MT90 (GL4) in the tranny and Redline 75w90 (GL5) for the rear diff.
Old 12-16-2012 | 08:52 PM
CCA4's Avatar
*Right click* aaaaaaand bookmark.
Old 12-16-2012 | 09:16 PM
Thats not the sound of a credit card being processed...
  #18
Old 12-16-2012 | 09:18 PM
CCA4's Avatar
Not gonna change it now, it's cold as **** outside and raining. I'll do what I usually do in the winter time and collect parts, then go nuts in the spring time
  #19
Old 12-16-2012 | 09:28 PM
I understand. Some parts do best after a short hibernation in the trunk over the winter. Really makes them blossom in the spring!
Are you eventually going eliminator? BAT?
  #20
Old 12-17-2012 | 10:22 AM
redmond1501's Avatar
I've been putting this off for a couple weeks after getting the Blauparts kit, which came with an extra quart of fluid.
I have a 98.5 tiptronic.
Do I need a large triple square bit or torx bit for the drain and/or filler plug?
