Transmission fluid capacity?
It is pretty much impossible to tell exactly how much fluid you will need. If you are doing a complete transmission overhaul you can go by the total fluid capacity but if you are just changing the transmission fluid, there is really no way to get all the old fluid drained out. That is why the change procedure calls for filling the fluid with the car level and the transmission at temperature. The procedure does not tell you how much fluid to use.
