trans swap
your looking to spend atlease 7k just as much as the car is worth
The supercharger should help a lot. From what I've read the gearing is well-suited to a torquey engine like that in the S4. The blower should help that quite a bit . Keep in mind that I don't think it's as simple as just a trans swap. You're likely to need the S4 axles, spindles, and quite a bit more as well.
Mate, yes. Work, no, not without alot more. You would need to swap out driveshaft, halfshafts, rear end, spindles, and shifter assembly. I'm probably missing something in there too.
makes more sense to buy a b6 s4 at that point
