Tranny Install Woes-Need Troubleshooting Advice
Old 06-28-2009, 03:31 AM
ghost6303's Avatar
well that car has an electronically controlled throttle so if the computer doesnt want you to press the throttle for some reason, it wont send the gas pedal signal to the actual throttle. if the TCU is telling the car there is a problem getting into gear or something, it might not let you rev the engine. is the part number on the original TCU the same as on the TCU for the transmission you got from the passat?
Old 06-28-2009, 02:43 PM
nhill2090's Avatar
I'm not familiar with where the TCU is located?
Old 06-28-2009, 03:05 PM
kendalll's Avatar
So you're trying to rev it up with the car on a lift? Perhaps its the traction control freaking out since the tires are 'slipping' in mid air?
Old 06-28-2009, 03:46 PM
nhill2090's Avatar
You know what, I'm kind of thinking you could possibly be onto something. I was just sitting here thinking that it may not have enough resistance for it to work properly as I just tried it again.
And for verficiation:the engine does NOT bog down when the gas pedal is hit. THe speedometer goes up to about 20 mph each time and the cv shafts spin, however the throttle really has no input.
So I'm wondering if Kendall might be sniffing the right track.
Old 06-28-2009, 03:53 PM
nhill2090's Avatar
Oh, and there is no MIL and I hooked up the code reader and there are no codes.
Old 06-30-2009, 09:22 AM
nhill2090's Avatar
Ok, just wanted to thank you guys for the help.
It appears to have been the trac control. I haven't taken it for a drive yet but it does appear to function correctly. I still need to pick up some more trans fluid and my power steering is empty? So I will need to get some of that too.
Oh, and which bank does Audi consider Bank 1. I have a code for an 02 sensor
Old 06-30-2009, 03:00 PM
kendalll's Avatar
goodtimes - by the way, how much did the used transmission set you back?
  #18
Old 06-30-2009, 11:48 PM
nhill2090's Avatar
$800 with 36,000 miles on it
Car is for sale if anyone knows anyone in the midwest (IL) looking for an 01 audi
GoSkins62
10-27-2008 06:33 PM
Hey_You
09-12-2007 08:20 AM
blakhaüs
08-17-2007 12:48 PM
noslipn
02-12-2007 06:35 PM
Milez
06-04-2006 03:56 PM
Quick Reply: Tranny Install Woes-Need Troubleshooting Advice
