Tire Size Question
Tire Size Question
I found a set of wheels on craigslist for a winter setup.
The wheels are 18x8 with a 35 offset.
The Tires on them are 2x 245/40/18
AND 2x 265/35/18
Blizzaks
I need to know if these would affect the quattro or not?
AND 2x 265/35/18
Blizzaks
If you calculate the difference its a 1.6% change in diameter.
I believe Quattro has as much as a 3% tolerance for diameter?
But it would be nice to hear from someone more educated on wheels.
I believe that the B5 models support a 57.1mm offset by default. Keep that in consideration. Since those are big wheels, make sure you have enough clearance for bumps on the road.
Some a**holes put huge wheels on a car that has been lowered too far. Then it looks stupid and performs like a Ford Model T
Stock 16" wheels clear the A8 brakes just fine.
15" and 16" audi OEM wheel pics 5x112 bolt pattern
that link right above has most of wheels that came stock on a few Audis from like 96-02 I believe. it helped me out a bit.
