Tire Rubbing Question
Old 03-08-2008, 07:31 PM
kolbs_91's Avatar
Default Tire Rubbing Question
I did search first, and didn't find anything of real help, so I thought I would ask. I just bought some 17" Enkei J10 wheels with Kumho ASX tires, and my car has Neuspeed Race Springs and Bilstein Sport Shocks installed on it. I don't really expect these to rub since they're only 17s, but I though I would get some more opinions.
If any more info is needed, just ask and I'll find it.
Old 03-08-2008, 07:38 PM
SuprA4's Avatar
Default RE: Tire Rubbing Question
check both wheel wells for noticable grinding...mine had a little give and i had quite a bit of missing plastic ha
Old 03-08-2008, 07:41 PM
kolbs_91's Avatar
They're not intalled yet - I just got them ordered today. I was just wondering if anyone had an issues with that size of wheel and suspension setup.
Old 03-08-2008, 07:49 PM
SuprA4's Avatar
i have 18'son my car and all i had was the wheel well rubbing at first....then the wheel bearing went bad driver side...but its been good for about 3 months now
Old 03-08-2008, 08:17 PM
turbo kraut's Avatar
Tech Guru
if all else fails.......roll them
Old 03-08-2008, 08:20 PM
kolbs_91's Avatar
ORIGINAL: turbo kraut
True enough.
Old 03-08-2008, 09:31 PM
Tech Guru
there is someone that just rented a roller from like ecs tunning.......
Old 03-08-2008, 09:56 PM
kolbs_91's Avatar
Hmmm...I'll have to look into that. I'll go ahead and have them put on at the shop, and if they're rubbing I can just throw the stockers back on for a while.
They should be in by mid-week...
Old 03-09-2008, 12:09 AM
ImTheDevil's Avatar
Tire rub isn't so much a factor of wheel diameter (unless you're trying to ball with 24s on your car) as offset. Long as you ordered the correct offset, you should be fine.
Old 03-09-2008, 04:05 AM
qUaTtRoA4's Avatar
they prolly will not rub...
go very slow over speed bumps/dips...if you go to fast, you'll end up rolling your fenders...lol
definately look into roolin your fenders, it's pretty straight forward with a heatgun and the roller tool...
can't wait to see pics of the new wheels!
there's a guy on here and audizine who has neuspeed race/bilstein and he's running 19x8.5" wheels and he isn't rubbing at all
here's his zine post http://www.audizine.com/forum/showpo...&postcount=325
sounds like you'll be fine
this thread is worthless without pics!
Quick Reply: Tire Rubbing Question
