timingbelt....???
#23
hahaa......when you said "come on up", I was like sweet he's in northern NY, I could shoot right over.....but noooo, man you're basically in PA!
#24
I'd say it's worth the drive... What's the going rate for your crew to do a TB, Jeremy? Is it up to a full case of beer, or just a 12 pack?
Wryfly, if you can turn some wrenches, the job isn't that bad... If not, a quick weekend trip to make some new friends and learn a little something isn't a bad idea... beats the hell out of spending a grand at a shop...
#27
here's the quick run down of needs....
-calipers and rotors all around with new break lines - the crap he pushed outta the lines when he bled it was apparently pretty nasty.
-two control arms
-already did tie rod ends
-sway bar link
-vac leaks
-MAF
-ABS modual
-I had a code for an O2 sensor, but maybe the vac leaks have something to do with that.
-drivers side mirror
-door lock motor thing
-did I mention timing belt
....so should i try to break it down and get through this list
OR
....off to auction
good times good times....
#30
I'm really leaning that way too. I've only had the car for 3 weeks, i've only put 210 miles on it and I already love the car. Figure I'll only like it more once everything is running the way it should.
you coming to vt anytime soon devil?? hahaa
there must be some VT techs on the boards....
