Timing Belt Won't Fit - Help
I'm trying to put a new timing belt in my 1.8t AWM and it is too tight to fit over the sprockets and pulleys.
The tensioner is the type that you compress with an M5 2 inch bolt which fits in a yoke and screws into the tensioner. Doing this, it released tension enough to get the old belt off.
The new belt is a Dayco 95306 which checks out as the right belt in online parts catalogs.
In compressing the tensioner, I went all the way to the bottom without finding the pin hole. This was after I got the old belt off. Could I have gone "over center" and have more tension on the pulley?
The problem is made worse by the tensioner pulley having a ridge on the outside as opposed to a flat surface pulley. Without the ridge, it might just fit.
I also tried taking off the small idler pulley to free up some slack, but it did not help very much.
Any help would be appreciated.
Many thanks,
John
Many thanks,
John
How much more clearance are we taking about here? Is it small enough that you could just move the cam sprocket a little bit to the right just to fit the belt and then move it back once it's on? as long as you're marked it shouldn't be a big deal.
Because I'm both cheap and lazy. I bought a new tensioner but it is the wrong one. The right one is hard to find and I gave up and decided to use the old one. I will call around in the morning to see if the right part is available. If so, I'll replace it.
Is it necessary to replace the tensioner at 114,000 miles?
Thanks again.
Also, I have moved the crankshaft sprocket and had to reposition it. I'm thinking a breaker bar wedged so the cranksaft can't turn when I turn the cam sprocket.
Thank you,
John
You're picking absolutely the last part you should ever be lazy or cheap about. The majority of timing-related engine fatalities on these cars are tensioner-related, not belt-related. I've seen exactly one worn timing belt out of all the timing jobs I've done. Saw a lot of worn tensioners though.
Might as well just toss a grenade on the manifold and close the hood. "Cheap and lazy" usually becomes "pissed and out of money" when this stuff is done. The endings aren't happy.
My 2 cents but I just done the same job on a 97 1.8T. There were 2 different belts. 1 had one more tooth on the belt than the other. I had 2 count the teeth on the belt to make sure I was getting the correct one.
I am sure there is another way but I did not know it.
I agree with the others. The tensioner was what went bad on mine as well. Probably should not skimp there.
