timing belt went bad
My timing belt went bad on the freeway today... the belt still has tension but when I crank it the cam is not moving. My question is will I need a rebuilt head and around much am I looking at?
99 1.8t manual
99 1.8t manual
With some new valves and other bits like head bolts you should be able to get it done for under $500 including the machine shop work. Find a shop that is familiar with multi valve heads. The pistons are probably fine. You'll know right away. If all you see is little 'smiles' on the tops of them you are good. Bigger dents may require more work or new pistons.
Well looks like I bent all the exhaust valves and 2 intake valves, none of the piston look overly damaged this one seems to be the worst one. The exhaust manifold has 2 cracks where the turbo mounts.....off to the junkyard.
Audiguruforyou
09-20-2011 01:31 AM
Jeffla
01-03-2010 04:43 AM
fritz
08-12-2007 02:55 PM
