Timing belt warning?
Old 10-21-2010, 09:28 PM
sa9023's Avatar
Default Timing belt warning?
Are there any real warning signs of a timing belt about to go? I've noticed some new noises inside the engine bay. One is a tick which I'm pretty sure is a lifter. The others are hard to describe so I'll try to get a video up soon.
Old 10-21-2010, 09:31 PM
briesa4's Avatar
you cant tell when its going to go until its happening
and its usually a tensioner that fails not the belt it will squeal and squeak if a tensioner is seized
Old 10-21-2010, 09:58 PM
sa9023's Avatar
yeah I don't hear any squeaks fortunately. but there's a lot of ticking going on and it worries me. also my exhaust seemed to get louder tonight? maybe it's just me. i put seafoam in earlier to help the lifters but i know that wouldn't cause that. I've heard that more exhaust can be a symptom of a bad timing belt tensioner
Old 10-21-2010, 10:00 PM
briesa4's Avatar
Ive never heard of an exhaust becoming louder with a bad tb. But where did you add the seafoam too?
oil gas and vac lines?
running it in the oil for miles can cause internal damage.
Old 10-21-2010, 10:03 PM
sa9023's Avatar
I added it to the oil. 1.5 ounces per quart of oil just like it says. I only plan on running it for about 100 miles then I'm changing the oil and filter.
Old 10-21-2010, 10:06 PM
briesa4's Avatar
ok keep in mind seafoam thins your oil substantially you may have a bad lifter
whats your mileage you might want to invest in doing your timing belt anyways
Old 10-21-2010, 10:09 PM
sa9023's Avatar
160,000 miles. A friend had the car before me and the guy he got it from has had around 20 A4's apparently. So I'm sure he changed it. But, $200 for the ultimate kit from ECS is a damn good deal.
Old 10-21-2010, 10:12 PM
briesa4's Avatar
that it is! I went through german for mine and around 160XXX youll be do soon if not already anyways
what year and engine size are you running
Old 10-21-2010, 10:53 PM
ImTheDevil's Avatar
Doesn't matter how many A4s he's had, if you don't have proof that it's done, do it. Remember, he couldve had 20 because they kept blowing timing belts
Old 11-12-2010, 12:38 AM
sa9023's Avatar
So I got my Ultimate timing belt kit in the mail today, and I guess I wasn't paying attention when I ordered. Should I have got the kit that included the dampener as well as the roller? The ultimate kit only has the tensioner roller
Quick Reply: Timing belt warning?
