Timing Belt questions
I just got a 98 a4 with the 2.8 a couple days ago. It has 140k miles on it. I have to assume the timing belt was done before, would the original last this long? The previous owner doesn't know either cuz he didn't have it long. I just made an appointment to have it changed, but they coudn't get me in until July 25th!! I don't want to take it anywhere else, cuz I've heard very good things about this shop. They gave me an estimate of $550-600. For T-belt, water pump, and whatever else is recommended for this procedure. Is that a good price? It's not my DD, but I'm a bit paranoid about driving it until then, which sucks. Is it justified?
Odds are the belt has already been changed once but with 140K miles you are due for another. I agree with Audisaurus, with an estimate of $550-$600 is almost low enough to make me think something is wrong (questionable) with the shop. If they will do it for that low, with all the components it's a no brainer, only slightly cheaper to DIY and far less frustrating.
finally, don't be paranoid about driving it. It should be fine
Finally got the car into the shop. I asked them to check over the whole car before doing the t-belt, and they said I need the following; spark plugs (original), valve cover gaskets (leak), air filter, oil change, cat converter (noisy and CEL), plus t-belt, waterpump, etc. Looking at $1300. I told them to go ahead and do everything. I payed 3000 for the car, 350 for tires and with 1300 for the maintenance/repairs I'll be in it 4650, and the car is worth 5000.
I'm sure I could do some of the stuff myself (even have an old cat, and can weld), but I figured I'd save the hassle. I'd probably be breaking spark plugs off in the head. Considering a timing belt etc. is about 1200 elsewhere, I'm not too frustrated.
This is a very reputable shop specializing in VW with nothing but 5 star reviews on google. My sister and her husband both have had great experiences there.
As long as they're in there, ask them to change the cam tensioner gaskets and half moon valley seals. It will be much easier for them to do while the engine is already apart for the timing belt job, and if there isn't already an oil leak from them, there will be eventually.
Also, have them check out the condition of the crankcase breather system. If it's all plugged up with gunk, have them replace that as well. Gotta keep the pressure out of the ccb system or the oil leaks will come back sooner rather than later.
Recommend this shop in your regonal forum.
All done
Here's the breakdown:
ECU FAULT READOUT
T/BELT
T/BELT TEN
TENSIONER ???
ROLLER ???
WATER PUMP
THERMOSTAT
SERP BELT TENSIONER
SERP BELT
V/C GASKET KIT
GASKET SET ???
COVER
CAMSHAFT SEAL
COOL SYST CONDITIONER
ANTI FREEZE
SPARK PLUGS
AIR FILTER
CABIN FILTER
OIL FILTER
OIL
SYTHETIC GEAR OIL
CATALYTIC CONVERTER
SHOP SUPPLIES
LABOR
TOTAL 1202.61
Could somone explain the ones i have ??? next to?
ECU FAULT READOUT
T/BELT
T/BELT TEN
TENSIONER ???
ROLLER ???
WATER PUMP
THERMOSTAT
SERP BELT TENSIONER
SERP BELT
V/C GASKET KIT
GASKET SET ???
COVER
CAMSHAFT SEAL
ANTI FREEZE
SPARK PLUGS
AIR FILTER
CABIN FILTER
OIL FILTER
OIL
SYTHETIC GEAR OIL
CATALYTIC CONVERTER
SHOP SUPPLIES
LABOR
TOTAL 1202.61
ECU FAULT READOUT
T/BELT
T/BELT TEN
TENSIONER ???
ROLLER ???
WATER PUMP
THERMOSTAT
SERP BELT TENSIONER
SERP BELT
V/C GASKET KIT
GASKET SET ???
COVER
CAMSHAFT SEAL
ANTI FREEZE
SPARK PLUGS
AIR FILTER
CABIN FILTER
OIL FILTER
OIL
SYTHETIC GEAR OIL
CATALYTIC CONVERTER
SHOP SUPPLIES
LABOR
TOTAL 1202.61
ECU FAULT READOUT
T/BELT
T/BELT TEN
TENSIONER ???
ROLLER ???
WATER PUMP
THERMOSTAT
SERP BELT TENSIONER
SERP BELT
V/C GASKET KIT
GASKET SET ???
COVER
CAMSHAFT SEAL
ANTI FREEZE
SPARK PLUGS
AIR FILTER
CABIN FILTER
OIL FILTER
OIL
SYTHETIC GEAR OIL
CATALYTIC CONVERTER
SHOP SUPPLIES
LABOR
TOTAL 1202.61
