Timing belt came loose
Old 02-12-2009 | 07:57 PM
5L1K's Avatar
Default Timing belt came loose
This morning before school, as I started the car and went back upstairs to let it warm up, I heard the rumbling from my engine stop, so I went back down to check it out. My engine wasn't running but everything else was still on, the check engine light was on. I turned off the ignition, and started it back up, and there was a bad squeaky noise from like a belt going crazy in the engine, so I immediately turned it off. With no time left, I found another ride to school.
I posted a video here about loud and obnoxious noises coming from my engine. My dad's workers took a look at it yesterday and said it was the tensioner belt, aka timing belt? A new part for it was being ordered and will be here next week. Meanwhile, they just put the belt back in place.
Now when I came back from school, I popped the hood to see what's wrong. Is it the timing belt? it is the belt at the very front of the engine behind the grill. Anyway, when I came home to check what was wrong, that belt was all loose and not hooked around the rotating tensioners.
How do I put it back in place? How bad can this be? and should I be driving it even though I get the belt back into place?
Old 02-13-2009 | 01:05 AM
Tweaked's Avatar
No, that's a drive belt. The T-belt is hidden behind the plastic covers attached to the engine.
No. It drives the alternator and power steering pump. If it snaps or falls off again, you'll be stranded.
When your car stalls out or the ignition is key on/engine off, the check engine light will come on. Replace the belt, tensioner, and any noisy pulleys to avoid getting stuck.
mgadcf
08-28-2011 11:55 PM
Site_Administrator
12-18-2008 09:50 AM
TJP13088
05-20-2008 03:07 AM
