Timing belt broke
#21
Almost one year later! Yikes. Anyways, I recently got it all back together and gave it a trial run with the front end still off in case anything major went wrong.
It started and ran. However I have a "clacking" coming from the passenger side head area.
I am led to believe that it is possible lifter/tappet/cam follower noise?
It HAS been sitting for well over a year now. Chances of lifters not operating properly? Or taking 20-30 mins to "pressurize"?
What would actual valve interference noise sound like compared to lifter noise? I don't think it would run if the valves were damaged, would it?
Compression shows 120-140 for all cylinders.
Don't know oil pressure on passenger side. Anyone know how to check?
As for the noise, it's the lifters. The will sound like pooh for some time but I promise it will go away. Been through a head off for a long time and it made the same noise.
#22
Was the compression done at temp and what was the highest and lowest? If it was, you are within range of variance but getting low in the lowest.
I'll do a 20-30 min warmup and see how it goes. Recheck compression then too.
Thanks!
#23
Without going into the whole story behind it, I find myself trying to figure out the damage done to my 2.8L 12V ('96 A4 Quattro).
Here is my plan to diagnose, please correct where needed.
#1: Use compression tester and check each cylinder one at a time to see what PSI is there. Looking for around 180, anything lower than (what? 100?) means bent valves. TB is gone, so I plan to rotate by hand (tools) the cam gears and check each cylinder. **Question - Where should I position the engine crank? Is there a position that will allow me to check all cylinders without interference?**
#2: Seeing as it happened at 65-70 MPH I am assuming bent valves. I plan to get some salvage heads and replace after checking the piston tops. I did not hear any loud noises or other indications of major damage, so hopefully they are ok.
#3: Remove, replace heads, gaskets, etc. **Is there anything else I should do or check while I am at this stage?** (Not just TB related)
#4: Replace TB, waterpump and oil seals. Manually turn engine over to check for correct timing.
#5: Button everything back up. Pray for success.
Any recommendations on head gaskets? Can I get a thinner gasket for a little higher CR? Engine has 106K on it, so...
#24
106K. Former owner says belt was changed. I believe him, the belt is the only thing that saved my engine!
Unfortunately the idler pulley and tension pulley both seized. It looks like the a fore mentioned owner also pressure washed/hosed the engine for re-sale attractiveness but all that water rusted the pulley parts.
#26
I ran it for a good 20 min warmup with a few brief 2000 RPM and 3000 RPM stints. Everything is "normal" sounding now. No weird sounds or vibrations anymore!! Time to put the front end back together and get it back on the road.
