Throttle Body Cleaner..Safe?
RE: Throttle Body Cleaner..Safe?
Its not the smartest thing to do. Why not take the 5mins to pull it? You just need to remove the hose to the TB and then the 4 5mm allen bolts and then remove the hoses and connections. Then you can spray away and then reinstall. Shouldnt take more than 10-15mins total
ORIGINAL: cincyTT
i used to work at tire lube place, and we did a "throttle body cleaning service"
i had a guy with a tahoe come in and wanted it done........ it was so fun listening to the enginge choke while we had his intake/airbox disconnected... then when the throttle body cleaner ignited.. i think he shot flames out the exhaust.....
i sprayed a **** load of it and waited like 10 min for it to dry and then started that bisch. it took a few cranks but it ran much better. auditech79 was telling a guy to crank his car while spraying because his car wasn't starting. so i think it's pretty safe
ORIGINAL: cincyTT
So everything connected to the TB is ok to remove? I looked at the thing a few times.. wish it would take me 10min to do
The 2.8 can run without anything attached to the TB. You can just remove the intake and spray it when its running. Im not keen on sucking that crap into the engine, but most of that crap is already in there anyways.
yeah I've got a 2.8.. i pulled the stuff out a bit more and disconnected things but there's no way in hell I'd ever be able to get the body off myself.. I dunno how you guys do it. I also noticed that while running it.. it smells kind of like burned popcorn... any ideas on that? perhaps just the acorns left around the engine ^_^
