things that go wrong with ALL A4's
Old 08-26-2008, 10:44 AM
CRAZYHAWK's Avatar
As I said, try spraying the cruise control switch with
RadioShack Contact Cleaner.
  #42
Old 08-26-2008, 05:56 PM
flyromeo3's Avatar
pphheewww...where do I begin:
Had OEM clutch replaced 96k
Oil pan - bottomed out in a pothole. Car is lowered anyway but I've seen A4's that arent dropped break their pan in a similar way
Wheel Bearings - LR, RR
Headlight switch - 2x
CV Joint - replaced whole axle instead
Radio - ERR error reading Cd changer - Removed and beat with a wooden bat.
Cooltant Temp Sensor
ICM's go too. I havent replaced mine.........not yet at least.
  #43
Old 08-26-2008, 07:39 PM
m6amba's Avatar
ok, i'll try it, do i HAVE to use radio shack? or is that the cheaper brand? but any will work?
ill stop after work tomorrow and grab a can....
  #44
Old 08-26-2008, 11:34 PM
andrewj654321's Avatar
coolant temp sensor this is my second one in 3 months
my car is in a shop as we speak to get fixed in the morning
so i get to drive my step dads b*&^#hin chiped duramax
  #45
Old 08-27-2008, 04:41 AM
outkast767's Avatar
How about the Cruise Control... Though ive only need it on thouse late night coming from the girls house so i don;t get in trouble with the popo... but how many of your guys Cruise Control has gone out...
  #46
Old 08-27-2008, 06:55 AM
lumend13's Avatar
on my first audi it never worked..
  #47
Old 08-27-2008, 10:02 AM
Maroon98's Avatar
We've had the B5 since new, so if I can remember correctly this is what has gone wrong:
-Sunroof switch replaced x2
-Heads re-machined
-Front wheel bearings
-Rear wheel bearings x2
-Front bumper lower grilles gone
-Drivers rear door lower trim gone, drivers door trim falling off
-Water pump replaced
-Coolant hoses replaced
-New front control arm
-Cracked oil pan
-Mass airflow sensor x3
-Coil packs
-Thermostat
-Failed turn signals
I'm sure I'm forgetting something...
Current probs:
-Radio cuts out every now and then
-Ongoing clutch probs
-Leaky flex pipe joint and/or holes in the exhaust system (I have to jack the car up to look)
-Mechanic said it needs a valve adjustment or valve seals - it burns oil and smokes on startup in the winter
-Cruise control doesn't work
-Sunroof has a mind of its own
I still love it tho!
  #48
Old 08-27-2008, 06:28 PM
Schwinn's Avatar
I purchased my car with 120,000 miles on it, now has 150,000 miles. I have had...
Belts, tensioners, and pulleys replaced
Water pump replaced,
Ball joints, cv joints replaced,
Lower trim is falling off,
Airbag light is on,
ABS light is on,
Interior lights don't turn on when I open the door,
Lines on the center console LCD,
Washer fluid leaks,
Blinker relay switch replaced,
Rear wheel bearings replaced,
Windshield washer motor and transmission replaced,
Thermostat replaced,
Cupholder doesn't pop out anymore,
I can't even remember what else has gone wrong... I do average 31mpg! 99 A4 1.8T
  #49
Old 08-27-2008, 10:56 PM
audiltr's Avatar
haha how about the loose driver inner door handle
  #50
Old 08-28-2008, 03:02 AM
Schwinn's Avatar
lmao I have the loose driver inside door handle as well!
Quick Reply: things that go wrong with ALL A4's
