things that go wrong with ALL A4's
#222
power steering pump goes out,cruise doesnt work a/c just stopped working yesterday, lumbar support breaks in drivers seat,$50.kit just to replace panel clips to see what broke ,havent done that yet, hah yet.afraid to touch the car in fear of setting off dash lights or airbags blowing if you try with the batt conected .not to mention the radio,didnt buy the car new so how much to find out the codes? this quattro is a nice car but i dont think any of us really know just how deep we really are!
#225
Serpentine Belt (fan belt) pulley
wheel bearings
drive side inside door handle (loose)
ABS/Brake light
Check engine light (goes off if i disconnect battery only to come back at 300 miles)
AC/HOT AIR fan makes a noise? not sure what this could be its almost a gurgling sound behind my vents
exhaust leaks (flex pipe)
tick
wheel bearings
ABS/Brake light
tick
#226
wheel bearings
ABS/Brake light
tick
wheel bearings
ABS/Brake light
tick
#227
Serp belt is easy to fix, even with the front end assembled. Wheel bearings are common on these cars. Door handle just needs the spring replaced - remind me on your way through - I have several. ABS/brake light is a wear indicator on the pads, bad/dirty wheel speed sensor, or (if you get 3 beeps at startup) a bad ABS controller that needs rebuilding. CEL needs to be scanned - we can do that too. Blower motor is on its way out or you have a bunch of **** hitting it that needs to be cleaned out. Flexpipes are a replacement job for a welding/exhaust shop. Ticking noise we can look into as well.
#228
Seafoam in the oil may take care of the tick. At first start, if it ticks for a second and goes away, it's normal. Blower motor I believe can be swapped out by removing the glovebox. They're cheap at a junkyard and should be a DIY.
#229
i have a 2003 1.8t a4. my esp light comes on shortly after i start the car and doesnt turn off until i shut it off. i have noticed since it has been on my rpm's will like cut out randomly and almost stall out? any ideas on what this is?
