things that go wrong with ALL A4's
#211
Issues, fixes and solutions!
B5 1.8T bought it used - I'm the third owner (bought it with 47K) and it only has 65K on the clock.
My 20K mile experience:
1. O2 sensor - fixed it at the Audi dealer for $400
2. CV boot joint driver's side - fixed it at a local mechanic for $150.
3. Passenger's front door lower trim molding - bought it online from OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning and replaced it myself; part cost $55
4. Driver's side front control arm at a local mechanic for $350 (he disturbed the ABS sensor in the process - had to go to the dealer to check what it was - they reset it for $100!)
5. Windshield washer pump - bought it online from my favorite website Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips for $11 and had it installed by a mechanic for $50 - do it yourself though.
6. Windshield washer hose was loose - it took me and my mechanic an hour to trouble shoot the issue - $50.
Things I haven't fixed (yet):
7. Loose inner door handle for the driver's side
8. Cup holder
9. The seat for the driver's side lower right leather panel is ripped
10. My steering wheel squeaks when I turn to the right
11. Power steering fluid was low the other day ...let's hope it is nothing bad
IMO, if you replace something, get the OEM parts otherwise you will have issues...I love getting my parts from these guys Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips, they have the OE(M) parts, they ship it fast and they are very cheap (for Audi parts that is).
Try to avoid the dealership; find a mechanic who you can trust and someone who will let you buy your own parts. Example: Audi dealership will charge you $120+ to replace the cabin filter and about the same for the air filter. I get them both OEM from autohausaz.com for $10 each and install them myself!
So long...
8. Cup holder
So long...
#212
Good choice on your selections for online parts shopping
#213
Only a few annoyances on my '01 2.8Q: trouble closing the sunroof, the inside trim near the headliner on the driver's side has fallen off(???), and the ubiquitous pixel failure on the message gauge. Other than that (I'm banging on my wood desk), I haven't had any other problems.
#214
Bought my '01 B5 in 2004 with 35K on it. As of today, it has 167234 miles.
Other than the normal maintenance, this is what I remember having issues with.
MAF at about 110K
Outer door trim replaced at 125K
LCD Display
Coolant temp sensor
Vacuum lines
Front inner CV boots
Right rear wheel bearings (5)
Left ear wheel bearings (2)
Rear top link bushes
Diverter valve
N75
Coil Packs, (7)
Arm rest lid
Rattle/ buzz somewhere in the dash
Creaking /groaning sterring wheel
Turn signal/Hazard light switch
Brake light switch
Header tank/Expansion tank split
"L" pipe to "suction pump" split
Left and Right side front axle output flange seals
Cam cover gasket
Engine/crank speed sensor
Personally, I think this is a remarkably low number of failures, even though some of them could have been prevented by Audi with a bit more fore thought. It is by far the best car I have ever owned and I plan on keeping it running until it is impossible to do so.
MAF at about 110K
LCD Display
Coolant temp sensor
Vacuum lines
Diverter valve
N75
Coil Packs, (7)
Arm rest lid
Brake light switch
Cam cover gasket
#216
Coolant leak please help!!!!
I have a A4 B5 1.8t and there is coolant leaking from a hose on the rear side of the engine and it has an electrical connector on it and I was wondering if anyone can tell me what that hose is and If I could get a part number?
#219
1997 Audi quattro a4 transmission issue?
I have a 1997 Audi quattro a4 and I am having issues with the transmission when you put it in gear it goes into drive reverse and neutral but when you give it gas it won't accelerate til high in the rpms and even then it seems like it has no get up and go its really sluggish I need help and maybe someone can give me some hints on how to fix it
