things that go wrong with ALL A4's
Old 12-14-2011, 03:32 PM
Cj3209's Avatar
Originally Posted by AudiInfantry
does your cruise get you back to speed if you have to brake and then turn it back on again, or do you have to get back to speed before you engage it again?
When I'm on cruise control and I brake, it doesn't go back to the cruising speed until I press the RESUME button. But, hey, I'm stoked my cruise actually works!
Going back to the vacuum pump in the trunk that give power to the door locks. Do you know what the fix is, knowing that there is a graphite disc that tends to crumble?
Thank you!
CJ
  #192
Old 12-14-2011, 05:03 PM
jonbonesjones's Avatar
Moderator
pull it out, pop the white top off, flip elec board out of the way. take out three screws around the cover, lift off cover and spacer. must not the way the oblong shape is. pop the graphite wheel off(which is probably cracked), theres 4 little pieces of plastic rectangles that go in the slots of the wheels. put new one on and reverse.
  #193
Old 12-14-2011, 06:12 PM
bradtyler02's Avatar
^this
  #194
Old 12-14-2011, 06:36 PM
Moderator
if you need help tell me i have dissembled one i can snap a picture its very straight forward
  #195
Old 12-14-2011, 06:59 PM
AVANT 1.8T's Avatar
Originally Posted by rsrbljan
ABS module... howmany of us here are driving with a permanant ABS/Brake light on...
*Raises Hand*
I am lol
  #196
Old 12-14-2011, 07:18 PM
Moderator
seriously ebay $50 life time warranty - i did it and haven't had one problem going on 6 months.
  #197
Old 12-19-2011, 03:07 AM
AudiInfantry's Avatar
Originally Posted by AVANT 1.8T
I am lol
I'm pretty sure a lot of us do. especially in the 99 year of the B5. All sensors check out, ABS is solid, but it just doesn't like it. You drive a quattro, It's only there in case you can't drive right haha
EDIT:
Inspection in germany is tough as ****. My inspection failed me for the light. so now i have to figure out how to flash it off. or just freaking unplug the dummy light.
  #198
Old 12-19-2011, 08:34 AM
Moderator
EDIT:
dummy lights are smd 3528 leds you will have to fix the problem
  #199
Old 12-19-2011, 09:21 AM
So just unplug that particular fuse? The last Audi i had was a 99 2.8 b5.5 and That light never went off either. No diagnostic fault for it either.
  #200
Old 12-19-2011, 09:35 AM
Moderator
unplugging the fuse would work I'm assuming but idk how it reflects the dummy lights?
Quick Reply: things that go wrong with ALL A4's
