things that go wrong with ALL A4's
#121
My transmission blew up at 107,000 miles. I have owned this car for 7 months and am sadly still able to find new cases of pure neglect from the prior owner! Most poeple I have talked to hate VW and Audis so the only place that willingly take my car and that I trust is the VW dealer. Getting a new racing tranny put in now from IPT. It handles twice as much power as a stocker and cheaper too! Transmissions are their specialty.So glad the engine runs so well. Had the new belts, leaks and everything fixed a couple days before the tranny blew.
#123
haha my cruise control only works once a day.. so you only have one chance to use it. I got the car with problems, fixed them and so far only have had minor problems. Gotta do alot of work this summer, clutch, tb, wp, k04 =), fmic and more crap..
#124
including B5 engine performance things and T10 connector
well ive been thinking and alot of new peeps have been asking about the same thing that fails, not only failing but usually the same thing on the same side.
example, its always the right rear ABS sensor that fails or the first wheel bearing to go is the right rear, my front right caliper froze today and from searching so did many others, 1.8t always break the t belt or get sludge, the 2.8s always develop a tick
anyone wanna add. hopefully it'll help some newbs.
#126
Oil pan FAIL!!
I was driving about 1/2 a mph through a parking space thinking my path of travel was un-obstructed when I was stopped abrubtly by a parking block. I figured I was traveling too slow to cause any real damage, but I was very wrong. The minor impact was enough to put a 3" diagonal crack in the SIDE of my oil pan. That's right, the side, not the bottom where it actually made contact.
Paper-thin cast aluminum makes a very vulernable oil pan.
#127
Airbag light is on..
Shifter bushings are shot, feels like i'm driving a 1990 F150 work truck
Control arms or bushings are going, I get clunks over bumps and wierd shimmy sometimes.
Rear drivers side window doesn't go down.
The car is perfect other than that. Stock floormats, the leather isn't even worn at all. 79k and its a '96 A4 QM
#128
2000 A4 quattro 2.8v6
I had to replace the rear wheel bearings and the hazard/turn signal relay switch (was confused when my turn signals stopped working out of no where).
- The side skirts are starting to fall off
- The auto-tint on my drivers side mirror is peeling off
- My hood latch froze (and I broke off the handle pulling on it trying to get it open)
- My trunk-lid shocks are crazy "tight" (meaning you have to really strain to open/close the trunk)
- Rear drivers side caliper froze
- The range on the keyless entry/alarm totally sucks
Other than that (haha) the car is in great shape, interior is flawless, power everything works, no dash warning lights, engine runs great, etc.
