things that go wrong with ALL A4's
Old 01-18-2009, 11:02 PM
gen2roller's Avatar
in my 98 had to replace radiator, power steering pump, and my secondary air pump, my sunroof would randomly open at times, oil seals were going bad, no cruise. Haven't had a problem with my 00, but the guy like worshiped this thing.
  #102
Old 01-19-2009, 01:56 AM
Witwer4444's Avatar
At least we dont have to worry about this happening
also, for those of us who like to pick fights, DO NOT show the punks your car
  #103
Old 01-19-2009, 09:39 AM
oettinger1919's Avatar
SoCal Crew Member
Well...
I think the biggest thing on mine has been having to replace the the steering rack and the front wheel bearings and boots, as well as the right joint but thats only because i ran on the thing with no grease in it for who knows how long.
My "non recall adressed" problems include the sunroof switch and the middle LCD display. I figure they skimped on top knotch diplays since that kind of thing was pretty new on a car in the mid-late 90's.
I remember everyone having problems with that ignition sensor. I cant remember the exact name but it caused poor idling and was almost a certain failure on all b5's.
Our cars are starting to become dinosuars. Im going to be so happy when i get a new job and i can put this thing away and only use it when it rains. Im hoping to start commuting to work on a bike.
does anyone here love Buell sportbikes as much as me?
  #104
Old 01-20-2009, 07:34 PM
mxmama101's Avatar
oil leak; second time to replace gasket! power steering fluid leaking A4 2.8 2001
  #105
Old 01-20-2009, 08:11 PM
pidkin's Avatar
Originally Posted by Schwinn
I purchased my car with 120,000 miles on it, now has 150,000 miles. I have had...
Belts, tensioners, and pulleys replaced
Water pump replaced,
Ball joints, cv joints replaced,
Lower trim is falling off,
Airbag light is on,
ABS light is on,
Interior lights don't turn on when I open the door,
Lines on the center console LCD,
Washer fluid leaks,
Blinker relay switch replaced,
Rear wheel bearings replaced,
Windshield washer motor and transmission replaced,
Thermostat replaced,
Cupholder doesn't pop out anymore,
I can't even remember what else has gone wrong... I do average 31mpg! 99 A4 1.8T
impressive with the mpg, but how much did that list cost you??
  #106
Old 01-20-2009, 08:24 PM
Splbasshead's Avatar
Man my cupholder does not work anymore either. The center display has like 60 % life of visability. I have chaned both front leaking differential seals. Mass air flow sensor.
  #107
Old 01-21-2009, 06:35 AM
a2thy's Avatar
Ha! my car has the same four problems as yours Splbasshead, except it's my rear diff that's leaking. There's a guy on Audizine that can fix our center displays.
  #108
Old 01-21-2009, 10:31 AM
Witwer4444's Avatar
really? can you bring that thread up with the guy that can fix center displays? thanks
  #109
Old 02-15-2009, 04:05 PM
lawsuit_boy's Avatar
Originally Posted by rsrbljan
ABS module... howmany of us here are driving with a permanant ABS/Brake light on...
*Raises Hand*
This is the one and only problem I have encountered with my '97 b5. It's currently at 120k and driving like a champ. I haven't had it check to find out if it's the module because ABS still works, but I'm going to get it taken care of soon. Those bulbs in the dash are going to burn out.
  #110
Old 02-16-2009, 12:25 AM
Originally Posted by Drfeelgood69247
Ill second that my *** is on fire when i set it to 6. lol
Haha, I don't usually go past one. Sometimes I'll set it to two for a few minutes, but that's it. I should try 6 to see what it's like.
Quick Reply: things that go wrong with ALL A4's
