Terrible Noise While Driving
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
There's a terrible grinding or metal on metal noise when driving, it's especially bad when turning.
Planning to call the mechanic tomorrow and flatbed it over, but just wondering what to expect.
I heard a metal against metal noise too, but mostly when turning a few weeks ago. It was the power steering pump, which I had replaced. It was back to normal again for about two weeks but the noise is back again so it's at the mechanic.. I'll let you know what they say it is, 'cause I may have the same issue as you.
if it's a wheel bearing, it will get much, much louder very soon. see if you can narrow it down to just one corner, then jack up that wheel and see if you can wiggle it back and forth. rotate the wheel too. if it's jerky and you feel a grinding, you know it's a wheel bearing. it should be a smooth rotation otherwise.
do you hear the grinding when turning both left and right? if it's a wheel bearing, it will only get louder when you turn in one direction.
