Tackling bunch of airbag codes 65535, 00532, 00588, 01025
Next on my list of endless issues with this 1996 A4 2.8 12V AFC are the airbag codes.
Considering the sheer quantity, am I dealing with a bad module? Do they have a tendency to fail? If the likeliness is high, would it be advised to get a used module and hope it fixes it?
Even so 3 of the 4 codes say intermittent, they are ALWAYS there (at least 10 time codes erased, battery disconnected, etc.); they consistently come back.
Where to start with the troubleshooting?
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D00
Coding: 00127
Shop #: WSC 06334
VCID: 3469E80D2EBD
4 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-10 - Open or Short to Ground - Intermittent
Coding: 00127
Shop #: WSC 06334
VCID: 3469E80D2EBD
4 Faults Found:
For trial/error (could be module or elements itself), I decided to buy a used module (alternative, if I knew the module is bad, have my module fixed for $50 on ebay). Worst case (if not the module), I can sell again.
Installed module yesterday. All airbag codes gone.
Hope it stays that way.
Bought this piece (thought it is the lamented 'clock spring' but not sure. Any idea what it is?
barto
01-30-2012 08:18 PM
