Suspension help
Old 08-07-2013, 09:04 PM
phatjames167's Avatar
Default Suspension help
I am running 235/40/18 tires and since i put the new wheels and tires I'm sitting kinda high. I found a brand new set of H&R race springs on craigslist. that will drop the front 1.9" and the rear 1.5". will I rub on the control arms or anywhere else?
Old 08-08-2013, 10:23 AM
McGovs2.7TB5's Avatar
probably. You may need a narrower tire (225/40-18 is most common) or some fender rolling to get the 235s to fit. The race springs, from what I remember when I was shopping them, have a pretty significant drop. I had the H&R sport springs and they were a bit more reasonable.
Old 08-08-2013, 10:56 AM
How would the fender rolling help? The control arms would still be super close of not rubbing. I'd rather have the sport springs but I found new race springs at a good price.
Here is what my control arms look like now. If I lower the car does the control arms move lower also or do they stay in place and the body of the car comes down?
Old 08-08-2013, 06:58 PM
CCA4's Avatar
Is your pinch bolt missing or broken?
Old 08-08-2013, 08:40 PM
when I did my axles I got one stuck trying to get it out and I had to try and do it the Audi way by taking the control arms off. Well the pinch bolt would not come out. I tried punching it out, drilling it out, dremmeled off the head of the head, and nothing worked. i finally got it towed to my mechanic and they couldnt even get it out with with an air punch. I figured I'd leave it until it either comes out and I'll pull over, go to get another pinch bolt jack it up and put it in or until I do my control arms and have the bolt heated up so it will move. that weekend was a pita.
Old 08-09-2013, 09:08 AM
Are you running Winter tires on the rear and something else up front? I thought mixing tread patterns was bad?
Old 08-09-2013, 09:12 AM
I got the tires like that. it's the same size tire but one out of 4 is different tread and brand. I got the wheels because I didn't like the stock wheels and needed new tires for inspection coming up so I got these and I'll probablly end up changing the tires in 6 months, but I'll have the money then. I just recently bought a house so funs were limited a bit.
Old 08-09-2013, 11:04 AM
CCA4's Avatar
I don't think mixing tread patterns is a huge deal as long as the diameter is roughly the same. Don't quote me on that though
Old 08-09-2013, 11:19 AM
quoted
Old 08-09-2013, 11:46 AM
so does anyone know the answer to If I lower the car does the control arms move lower also or do they stay in place and the body of the car comes down?
Quick Reply: Suspension help
