Sunroof ?
Old 03-09-2010 | 06:10 PM
lolo22's Avatar
Default Sunroof ?
Let me just start off by saying im new to the audi scene just picked up my first a month ago and by far the best car Ive ever owned. Just wondering on the sunroof besides a fuse is there any other reason why It may not work is there a relay or something else. Its a 1998
Old 03-09-2010 | 06:45 PM
aRIf's Avatar
motor could be dead.
also sunroof switch can fail. push the switch up gently and turn it to see if any thing. sunroof switch is a common problem on audis. switch sometimes lose connection u have to take the cover off and unscrew 2 screws to fix it. easy job, takes < 5mins.
Old 03-09-2010 | 06:46 PM
Andrew149's Avatar
never heard of one not working when you open the driver side door there a panel pull that off
Old 03-09-2010 | 09:34 PM
CCA4's Avatar
bad sunroof motors/switches are fairly common on B5's. for the record, OP, there's a little crank on the inside of the fuse panel door that you can use to close the glass if it gets stuck open
Old 03-09-2010 | 10:40 PM
pullacowonaski's Avatar
there is also a diy on how to clean the contacts i need to do that to mine it acts all funny
Old 03-11-2010 | 07:31 PM
lolo22's Avatar
Turns out the switch wasnt pluged in I guess for a reason. I pluged it back in and cleaned the contacts and when I turned it on it made a loud clicking noise it opend but then wouldnt shut and I had a hard time doing it manually cause it would just keep clicking like its stripped. The noise is coming from the location of the screw to close it manually. Any Ideas.
Old 03-21-2010 | 03:50 PM
rawdney88's Avatar
im in the same boat with my audi a4 1998 2.8L v6 , opens fine, won't close. manually it sounds like a gear is loose or stripped. quite annoying.
mrocke440
11-20-2010 10:11 PM
tariqahmad
10-16-2009 12:49 PM
18T
05-15-2006 09:27 PM
a6speed
12-10-2005 08:18 AM
TheHolyGhost
08-10-2005 02:31 PM
