stock internals
RE: stock internals
i dont havt a pic, but depending on the year of your car, the stock internals can take 350 to 400 ish crank hp. the 1999 and earlier (maby 2000, im hella drunk sooo...) had 20mm pins while the later ones had 19mm pins. but basically, unless you go huge turbo like gt30 turbo, you should be fine. gt2871r turbo is run by many on here but you are running to the limits
RE: stock internals
lol true. if you go with a large turbo that spools sooner you will produce more torque and risk throwing a rod. a turbo that spools later depending can risk blowing something else. like spinning a bearing or youre valves floating (which will not break your engine but isnt god for power).
but to toextreme, ya, torque throws rods but for the internals, the only way i have heard them rated at is horsepower not torque. i guess it is because there are not that many common large turbo options to chose from so looking at the advertised HP you can figure it out.
RE: stock internals
well a GT2871r is the "unofficial" limit for the stock rods. The stock valves can rev to 7800 without floating and the stock pistons or are good to 500hp or so. The weakspot is the rods and are the only thing that need to be replaced when going BAT
RE: stock internals
ORIGINAL: AudiCross
and for the record. with a good tune. the 1.8t will handle 400bhp all day long
