Stock boost psi and vacuum inHg?
Old 07-05-2009 | 12:31 PM
xdewaynex's Avatar
ive been looking for this answer as well. i put a autometer boost gauge in my 98 a4 a couple weeks ago, and its showing 10-11psi when i get on it. i thought it would only be in the 5-8psi range.
Old 07-05-2009 | 04:53 PM
2fast4u66's Avatar
Autometer boost gauges give you an extra 2 psi
Old 07-05-2009 | 07:00 PM
a2thy's Avatar
I have a Glowshift boost gauge. It's displays about 1/2 to 1 PSI lower than what it should be. I know this because it sits at about 1/2 to 1 inHg when the car is off. Any way to adjust this?
Old 07-08-2009 | 07:19 AM
a2thy's Avatar
I emailed GIAC and they have no record of tuning an ECU with my VIN. I'll ask every well known chip tuning company until I find out where my mystery chip is from.
Old 07-09-2009 | 01:14 AM
kraylon's Avatar
it is really hard to find out what chip you have. i spent about 3 months trying to figure it out and email every chip company that i could find and no one had a record of my vin.
i bet what happened in my car is the former owner tradred a stock brain for a chipped brain which goes on all the time, and since i have no idea what the vin of that car was i am unable to find out whos program is in it
Old 07-09-2009 | 07:22 AM
a2thy's Avatar
That sucks, looks like I may have the same problem.
Would any tuning company be able to tell if my car is chipped?
Old 07-09-2009 | 11:43 AM
Mike-2ptzero's Avatar
Well its better to be chipped and not know which tuner then not be chipped at all.
  #18
Old 07-10-2009 | 04:17 AM
a2thy's Avatar
To add to the confusion, I noticed that I'm no longer getting that excessive boost. It only peaks at about 7 or 8 psi now. Also my CEL is no longer on for some reason. I'll check it with my vagcom just to be sure.
  #19
Old 07-10-2009 | 09:01 AM
Most likely in limp mode now.
  #20
Old 07-10-2009 | 10:53 AM
a2thy's Avatar
Ok, now it's back to the way it was before, peaking around 21 psi.
Limp mode is around 7 or 8 psi? It felt somewhat normal, not excruciatingly slow like I figured limp mode would be. You may be right though, I don't have that much experience with these things.
I've also noticed the boost comes in kind of inconsistently, feels like it's hesitating. A problem with the N249 valve I'm guessing?
