still no boost
Old 05-21-2009 | 02:19 PM
Audacity's Avatar
Default still no boost
got it scanned it showed a p1136. to lean. a hose leak most likely. so i find it. its the line from the intake manifold to the dv. right where the T fitting is to the boost gauge. so i replace the whole line but still no boost. vacumm is about where it should be though. made sure all of the connections were tight. i can't find and visible holes. im so discouraged. =[.
Old 05-21-2009 | 02:31 PM
Mike-2ptzero's Avatar
Did you try resetting the ecu by clearing the codes with the vagcom or unplugging the ecu? If you do unplug the ecu make sure to do a throttle adapt by turning the key on for 30 seconds before starting the engine.
Doing this will reset the fuel trim blocks causing the ecu to adapt again.
Old 05-21-2009 | 03:00 PM
Audacity's Avatar
no i didn't. i don't have a vag-com and i didn't know about that ill be sure to give it a try for sure.
Old 05-21-2009 | 10:50 PM
zadeluca's Avatar
if you've got no boost shouldnt you take the 18psi out of your sig? j/k
just thinking out loud here... how do you know you have no boost? if you say because your boost gauge is not showing any boost, are you sure that its hooked up properly and not defective?
Old 05-22-2009 | 12:54 PM
Audacity's Avatar
yeah im sure its hooked up properly, they are pretty bulletproof. and i can't hear the turbo spool. but anyway i disconnected the ecu. still nothing.
Old 05-22-2009 | 03:47 PM
TheProfessor's Avatar
what is it showing for vacuum on the gauge at idle?
Old 05-24-2009 | 06:02 PM
Audacity's Avatar
like 14 or 15 i know its a little low. i just cant find the damn thing.
TeeterTawter
01-20-2013 01:14 PM
to4xxx
06-08-2012 12:56 PM
BUCKET O BOLTS
07-28-2008 09:15 PM
eliTTe
10-11-2007 05:12 PM
onepoint8tee
06-27-2007 05:38 PM
